I recently purchased the INNOVV K6, and I have to say—it’s absolutely brilliant! This dashcam has exceeded my expectations in every way, offering top-notch video quality, a sleek design, and effortless installation.
Crystal-Clear Video, Day or Night
The 2K Quad HD front camera and 1080p rear camera capture stunning footage with sharp details, even in low-light conditions. Thanks to the Sony STARVIS sensors, night rides are recorded with clarity, making it perfect for safety and documentation.
Built for the Road
What really impresses me is its rugged build—the IP67 waterproof rating means I don’t have to worry about rain, and the aluminum alloy housing keeps it cool and durable, even on long rides. Plus, the 140° wide-angle lens ensures I never miss anything happening around me.
Hassle-Free Installation & Power Options
Unlike other motorcycle dashcams, the K6 is super easy to install. The integrated DVR in the front camera means there’s no bulky control unit to mount. I also love the flexible power options—it can run off a USB power bank or be hardwired directly to my bike’s battery.
Final Verdict? Worth Every Penny!
If you’re a motorcyclist looking for a reliable, high-quality dashcam, the INNOVV K6 is a must-have. It’s discreet, powerful, and gives me peace of mind every time I ride. Highly recommended!
Nicely made bit of kit , comes with usb connection or hard wire to the battery. An easy to use APP to be be able to see where you have been
Very happy with how the installation turned out. I let my garage install the wiring in the wiring harness of the bike and the rest I did myself. It is a straightforward installation but you need to take your time for the install. The camera's are good quality so is the rest and the image quality in good/bad/dark environments exceeds expectations. In General very happy with this purchase. Side note, for the installation of the rearview camera I made a hole in the body work in order to have the cable stowed away nicely, this hole was then filled with silicone so no water/dirt can enter this was.
The system works as advertised. It is easy to install. Routing the wires takes most of the install time. The unit is nice and compact. Warning is okay, although I would prefer the warnings a bit earlier. Esp at low speed difference I find the safety space a bit on the low side. The supplied tape to fix the mirror lights is very weak. The tape did not secure the warning lights at speeds over 100k.
This is mounted on an FJR 1300. I have a Mounting rail above the instrument panel to bring the GPS int the field of view. I printed mounts for the indicators at the ends of the rail. This brings them into the lower scan view. The installation was easy, the power coming from a distribution block. The rear radar unit is mounted on the license plate rail on the left side (the INNOVV dash camera is on the right side. The performance is exactly as stated monitoring targets for relative closing speed. The alerts are appropriate. In higher density traffic and stopped traffic you can keep your eyes forward and be aware of changes behind. It only needs to help you once to be worth it.
